NAT Traverse OK/!OK
ZEE
NAT Traverse OK/!OK
Post by ZEE » Mon Jul 01, 2019 6:49 pm
The objective is connect from a remote PC
to a private IP device inside a LAN
behind a router with NAPT (the usual ISP supplied routers)
( LAN IP(s) are in range 192.168.1.0/24 or 10.0.0.0/8 )
(access from a external client to a internal machine that has the SE-Hub/Bridge)
When connecting using *.vpnazure.net DDNS it works
I can do NAT Traverse over a ISP router
(only using SSTP VPN in port 443/HTTPS)
but the connection is rather slow...
When connecting using *.softether.net DDNS
I can´t connect with neither protocol (SSTP:443/SE-VPN:555/OpenVPN/...)
nothing seems to work...
My preference would be
to connect using the SE-VPN Protocol over port 5555/TCP
Anybody cares to give a explanation on how to this...
and if possible gave some technical insights
over why VPNAzure works but SoftEther.net don´t...
(I´m not talking about the DDNS, that works OK)
Tested with Thomson, Hitron, Asus, TP-link, etc. router
Thanks, ZEE
centeredki69
Re: NAT Traverse OK/!OK
Post by centeredki69 » Mon Jul 08, 2019 11:42 pm
ZEE - "behind a router with NAPT (the usual ISP supplied routers)" & then "Tested with Thomson, Hitron, Asus, TP-link, etc. router".
---Are you double NATed meaning ISP router & then one of the Thomson, Hitron, Asus, TP-link at the server location? If so it will be hard for SE to transverse a double NAT
ZEE-I can´t connect with neither protocol (SSTP:443/SE-VPN:555/OpenVPN/...)
-----The NAT-traversal will only work using the SE protocol or the SSTP:443 with Azure.NEt enabled. All other standard protocols will need port forwarding.
centeredki69
Post by centeredki69 » Tue Jul 09, 2019 12:00 am
ZEE- Anybody cares to give a explanation on how to this...and if possible gave some technical insights over why VPNAzure works but SoftEther.net don't...----------Yes it should be possible.
---With VPNAZURE your SE Server establishes and maintains a connection from inside your firewall out to a relay server hosted on MS Azure by the SE/Un of Tsukuba developers for FREE. When a client connects using the VPNAzure it is connecting to the relay server which then send only the authentication info to your SE server and once authentication is complete a direct connection is made from the client to the SE server so all payload data is direct and not through the Azure server. The softEther.net is a direct Dynamic DNS
kls
Post by kls » Sun Sep 15, 2019 5:57 am
I know this is very old thread, but it is the only one mentioning double NAT. Is it true that SE won't work with double NAT without going through VPNAzure?
