Latency throughput
snowymoountain
Latency throughput
Post by snowymoountain » Wed Jul 03, 2019 8:45 am
We have two offices one in UK and one in California, the latency is 132ms and so throughput is limited to around 2.5 MBytes per second I am wondeing what maximum throughput could we achieve using SoftEther ?
I have also downloaded the software and installed on a mac I can't see the option to raise the TCP/IP sessions
The advanced option "optimisation of VPN communication" I can't find it....
Where is this setting ?
Thanks
Rob
centeredki69
Re: Latency throughput
Post by centeredki69 » Tue Jul 09, 2019 12:19 am
These settings are found on the "client software" under the under VPN connection properties or the cascade connections properties of the "Server or bridge software"
