Assign IP and limit access to other ressources
lobito1965
Post by lobito1965 » Sun Jul 07, 2019 6:02 am
Hello Gurus,
I want:
1-Assign static IPs to vpn users from the SoftEther, both inidividuals and groups.
2-Allow access and prohibit access to certain IPs in my lan so that they access only certain resources, as they are from a firewall.
Thanks for your help!
centeredki69
Re: Assign IP and limit access to other ressources
Post by centeredki69 » Mon Jul 08, 2019 10:49 pm
The static Ip address i don't think can be done. But you can control access to resources on a user or group or all VPN clients using the "Manage Access List" under the virtual Hub properties.
lobito1965
Post by lobito1965 » Mon Jul 29, 2019 7:02 pm
SOLVED. Thank you centeredki69!!!
"Manage Access List" is the solution. I add single IP's (/32) and subnets (/24) with Priority value and Pass/Discard in Action.
