I have a Softether Server installed on a Windows Server 2012 R2 ,and i have opened all ports necessary like 443 or 992.
In a client, i have installed Softether client and introduced the certificate of the user. The vpn is connected but it doesnt work. I cant see any computer in the other lan. I tried yo change manually ip but it seems that the result is the same. I cant ping anyone.
What i have to do?
VPN Connected but i cant see anyone
Re: VPN Connected but i cant see anyone
Did you create a "local Bridge" ? or are you using "secureNat"?
I have tried both
Is the Windows Server 2012 R2 a virtual Machine or physical hardware?
Did you try to change IP protocols or VPN tunneling protocols?
