VPN Client Manager
razvan
VPN Client Manager
Post by razvan » Tue Jul 23, 2019 6:02 am
I got a new laptop which has only wi-fi network available (I think here is the problem). I downloaded the VPN Client Manager, but it doesn't show me the list of ips like it was showing on the old laptop.
On the old laptop it was showing me like this with "VPN Gate Public VPN Relay Servers" (see the second picture)
On the new laptop it shows me like that without "VPN Gate Public VPN Relay Servers" (see the first picture)
Where can be the problem?
Thanks!
centeredki69
Re: VPN Client Manager
Post by centeredki69 » Tue Jul 23, 2019 5:48 pm
That is because you downloaded the "softether Client" only
You need to download the "SE client with VPN-Gate plugin"
see the link below
https://www.vpngate.net/en/download.aspx
razvan
Post by razvan » Wed Jul 24, 2019 1:51 pm
Thanks a lot.
