VPN client does not connect
Battosai13
Post by Battosai13 » Wed Jul 24, 2019 4:23 pm
After I try to connect to a server, it says error try again. Help will be appreciated
tempest8008
Re: VPN client does not connect
Post by tempest8008 » Wed Jul 24, 2019 7:59 pm
You'll need to provide some more information.
Are you using SoftEther as both the client and the server?
Are you using SecureNAT on the server side?
How do you have your certificates configured, or are you using a Username/Password setup?
I can go on. There are a lot of potential solutions to your problem depending on what the problem actually is.
