Is SoftEther VPN compatible with Microsoft Windows10 64-bit?
Claudis
Post by Claudis » Thu Jul 25, 2019 2:21 am
Is SoftEther VPN compatible with Microsoft Windows 10 64-bit ? Thank you
centeredki69
Re: Is SoftEther VPN compatible with Microsoft Windows10 64-bit?
Post by centeredki69 » Thu Jul 25, 2019 3:12 pm
According to the spec sheet YES
Claudis
Post by Claudis » Thu Jul 25, 2019 5:26 pm
I did read anywhere where it is compatible with Microssoft Windows 10. More people would the software if it specified that. What is the difference between the client and server ? Thank you
centeredki69
Post by centeredki69 » Thu Jul 25, 2019 6:08 pm
Supported operating systems are listed.
https://www.softether.org/3-spec#Suppor ... ng_Systems
A VPN-server is what the clients connect to. It can be software or hardware or both. Softether is software type of VPN-server. Thousands of clients can connect to a VPN-server.
A "VPN client" is usually software and is used to connect to a "VPN-Server" These are sometimes built into the Operating system (Windows, MAC, iOS, Andriod) or can be 3rd party applications like openVPN. Softether has its own client that is used to connect only to a SE-Server.
