hi guys
i have a problem with ovpn config file
when i export ovpn file it does not contains certificate inside
and when i want to import config file and connect using openvpn
i get this error:
mbed TLS: ca certificate is undefined
Certificate problem
nmcbride
Re: Certificate problem
I'm having this issue too, have you found a solution by chance?
macbookprouser
Hi guys,
I am browsing forum for same problem and found the thread
https://www.vpnusers.com/viewtopic.php?f=7&t=64356
After adding dummy certificats OpenVPN client is trying to connect but is not connecting properly and just keeps trying. Will talk with IT in the coming days and work in finding logs on connection.
Any input on finding logs?
