SoftEther VPN protocol + SSTP VPN protocol = routing bug?
superleech
Post by superleech » Tue Jul 30, 2019 6:59 pm
Steps to reproduce the problem:
1. Connect to SoftEther VPN server (Ethernet over HTTPS)
2. Then connect to an SSTP VPN server
3. Google search what is my IP
4. Google shows IP from the SoftEther VPN server instead of from the SSTP VPN server
Does anyone have a fix or a workaround for this bug?
sky59
Re: SoftEther VPN protocol + SSTP VPN protocol = routing bug?
Post by sky59 » Wed Jul 31, 2019 4:26 am
You have vpn inside vpn? Make description . Your info is nothing
redog
Post by redog » Fri Aug 02, 2019 6:38 am
check route table ?
route print
