connection but no change in internet ip address
meadowde
Post by meadowde » Fri Aug 09, 2019 8:54 pm
I have setup a softether server on my home pc and softether client on my laptop. laptop and home pc are connected to different laptops.
selected in server setup to use vpn azure
I can connect and ping the server, but there is no change in my ipaddress of my laptop computer.
posts have been open in windows firewall by softether 443/tcp. using same in client.
have tried 5555 port also. no change.
any thoughts?
centeredki69
Re: connection but no change in internet ip address
Post by centeredki69 » Sat Aug 10, 2019 5:50 pm
Where is the Client Laptop located when you try to connect to your home SE-server? Does the Client Laptop display a popup after it connects telling you is received an IP address from the remote DHCP server?
Did you enable the "Local Bridge" OR "sercureNAT" feature on the SE server?
https://www.softether.org/4-docs/1-manu ... al_Bridges
https://www.softether.org/index.php?tit ... CP_Servers
