OpenVPN config
Chris663
OpenVPN config
Post by Chris663 » Fri Aug 23, 2019 11:48 pm
I've recently updated to the most recent Softether Server installation on my Ubuntu 18.04 server. I am trying to create a OpenVPN config through the application on my windows computer and ever since I updated I get this error when I try to use the auto generated config on openvpn: Options error: You must define CA file (--ca) or CA path (--capath). I have never had this problem in older versions so I am confused, please help.
Mcicool
Re: OpenVPN config
Post by Mcicool » Tue Aug 27, 2019 9:49 am
I made this work with following additions to generated config:
So basicly you connect to Sofether-OPenvpn server using User/pass auth method but also specifying certs...
auth-user-pass
<ca>
-----BEGIN CERTIFICATE-----
YOU ROOT CA CERT CONTENTS
-----END CERTIFICATE-----
</ca>
<cert>
YOUR CLIENT CERT CONTENTS
</cert>
<key>
-----BEGIN RSA PRIVATE KEY-----
YOUR CLIENT PRIVATE KEY CONTENTS
-----END RSA PRIVATE KEY-----
</key>
Chris663
Re: OpenVPN config
Post by Chris663 » Wed Aug 28, 2019 1:23 am
I don't know how to make the certificates that's the main problem
Mcicool
Re: OpenVPN config
Post by Mcicool » Mon Sep 02, 2019 11:58 am
The easiest way to manage selfsigned certs (if you are a Windows user) - use xCA programm.
klsop
Re: OpenVPN config
Post by klsop » Mon Oct 14, 2019 10:33 pm
How would you add the generated ROOT CA and server certificates to the OpenVPN installation of SoftEther?
lucaswallace
Re: OpenVPN config
Post by lucaswallace » Wed Oct 16, 2019 3:10 pm
Try using xCA programm.
