Best VPN
fenice
Re: Best VPN
The one that works for you and does what you need. There's no such thing as "the best" without a description of what you're actually looking for.
BTW, you do realise that SoftEther VPN is a VPN server that you install on your server and then use that, don't you?
sky59
Re: Best VPN
SoftEther :) It really goes through firewalls.... but you must connect with SoftEther client, not client that uses protocol that firewalls block
