Back Door
gogotha
Back Door
Post by gogotha » Mon Sep 16, 2019 12:59 am
I have been playing around with the software on a couple of Windows Servers and so far it looks like a good alternative to RAS server if I can figure out how to put on linux. I am curious why the 2 I set up are calling home to 130.158.6.56:80 and 130.158.6.60:5004, the Dymanic DNS service is turned off. Can someone explain why is the software calling back to the college? This communication is happening 3 to 7 times a minute.
gogotha
Re: Back Door
Post by gogotha » Mon Sep 16, 2019 1:45 pm
This is just the connection, it is blocking UDP, what would cause this outbound traffic? What is this connection for?
2019-09-16 08:40:06;Japan;192.168.88.2:62806;130.158.6.56:80;UDP;Blocked
2019-09-16 08:40:10;Japan;192.168.88.2:8391;130.158.6.68:5004;UDP;Blocked
2019-09-16 08:40:30;Japan;192.168.88.2:8391;130.158.6.68:5004;UDP;Blocked
2019-09-16 08:40:38;Japan;192.168.88.2:8391;130.158.6.68:5004;UDP;Blocked
2019-09-16 08:40:56;Japan;192.168.88.2:62806;130.158.6.56:80;UDP;Blocked
2019-09-16 08:41:03;Japan;192.168.88.2:8391;130.158.6.68:5004;UDP;Blocked
2019-09-16 08:41:29;Japan;192.168.88.2:8391;130.158.6.68:5004;UDP;Blocked
2019-09-16 08:41:46;Japan;192.168.88.2:62806;130.158.6.56:80;UDP;Blocked
2019-09-16 08:41:54;Japan;192.168.88.2:8391;130.158.6.68:5004;UDP;Blocked
2019-09-16 08:42:10;Japan;192.168.88.2:8391;130.158.6.68:5004;UDP;Blocked
2019-09-16 08:42:19;Japan;192.168.88.2:8391;130.158.6.68:5004;UDP;Blocked
2019-09-16 08:42:36;Japan;192.168.88.2:62806;130.158.6.56:80;UDP;Blocked
2019-09-16 08:42:46;Japan;192.168.88.2:8391;130.158.6.68:5004;UDP;Blocked
2019-09-16 08:43:13;Japan;192.168.88.2:8391;130.158.6.68:5004;UDP;Blocked
gogotha
Re: Back Door
Post by gogotha » Sat Sep 21, 2019 2:14 am
No back door and thank you Japan, nice feature! I actually have a few systems on a Win Rras that are experiencing "Keep Alive" issues.
