I've set my SE to run over wireless, so the underlying Pi running Ubuntu 18.04 is connected to the WIFI and then SE creates a tap interface to allow VPN connections in.
SSTP clients can connect fine, but only to the Pi, nothing else on the local WIFI network.
I did try creating another local bridge to the current hub with the WLAN0 interface, but this didn't resolve it.
Any suggestions?
Cheers!
Can't access any other local devices - WLAN
cmpts_cpeacock
cmpts_cpeacock
cmpts_cpeacock
Re: Can't access any other local devices - WLAN
Ok, saw this when actually creating the bridle over wlan0. See attached.
Is there any plan to supporting this, or even a workaround so I can keep wlan and still access any devices on my network (like I do on another server over eth0)?
Chris
Chris
