Update SoftEther VPN
intra1910
Post by intra1910 » Wed Oct 02, 2019 12:46 pm
I have SoftEther version 4.21 (build 9613). How can I update it by keeping my configuration please? A tutorial?
Thanks you! :)
intra1910
Re: Update SoftEther VPN
Post by intra1910 » Wed Oct 02, 2019 12:58 pm
I would have just installed "softether-vpnserver_vpnbridge-v4.29-9680-rtm-2019.02.28-windows-x86_x64-intel" on the same location of my installation and the VPN has updated itself. Very simple !
So, another question, to migrate this to another server (go from 2012R2 in 2019), where to take and where to return the configuration file please?
Thank you! :)
ozone
Post by ozone » Wed Oct 02, 2019 1:19 pm
How about:
"Edit config"->"Safe to file" on the old server, then "Edit config"->"Import file and apply" on the new.
intra1910
Post by intra1910 » Wed Oct 02, 2019 1:30 pm
Thanks ! :)
