SoftEther VPN hub DHCP problem
akbarsdigital
Post by akbarsdigital » Thu Oct 03, 2019 9:19 am
Hi everyone!
When user connects to the HUB he is resieve the link local DHCP address 169.254.x.x, but the server give the right IP address. But on other hubs everything works correctly, what could be the problem? I attach ipconfig files and a log with wireshark.
Wireshark log
------------------------------------Discover---------------------------------------
Dynamic Host Configuration Protocol (Discover)
    Message type: Boot Request (1)
    Hardware type: Ethernet (0x01)
    Hardware address length: 6
    Hops: 0
    Transaction ID: 0x781c9008
    Seconds elapsed: 0
    Bootp flags: 0x0000 (Unicast)
    Client IP address: 0.0.0.0
    Your (client) IP address: 0.0.0.0
    Next server IP address: 0.0.0.0
    Relay agent IP address: 0.0.0.0
    Client MAC address: 5e:ab:fd:34:76:84 (5e:ab:fd:34:76:84)
    Client hardware address padding: 00000000000000000000
    Server host name not given
    Boot file name not given
    Magic cookie: DHCP
    Option: (53) DHCP Message Type (Discover)
    Option: (61) Client identifier
    Option: (12) Host Name
    Option: (60) Vendor class identifier
    Option: (55) Parameter Request List
    Option: (255) End
    Padding: 00000000000000000000
------------------------------------OFFER---------------------------------------
Dynamic Host Configuration Protocol (Offer)
    Message type: Boot Reply (2)
    Hops: 0
    Seconds elapsed: 0
    Your (client) IP address: 192.168.30.10
    Next server IP address: 192.168.30.1
    Magic cookie: DHCP
    Option: (53) DHCP Message Type (Offer)
    Option: (54) DHCP Server Identifier (192.168.30.1)
    Option: (51) IP Address Lease Time
    Option: (15) Domain Name
    Option: (1) Subnet Mask (255.255.255.0)
    Option: (3) Router
    Option: (6) Domain Name Server
    Option: (121) Classless Static Route
------------------------------------Request---------------------------------------
Dynamic Host Configuration Protocol (Request)
    Hops: 0
    Seconds elapsed: 0
    Magic cookie: DHCP
    Option: (53) DHCP Message Type (Request)
    Option: (50) Requested IP Address (192.168.30.10)
    Option: (81) Client Fully Qualified Domain Name
    Option: (255) End
------------------------------------ACK---------------------------------------
Dynamic Host Configuration Protocol (ACK)
    Hops: 0
    Seconds elapsed: 0
    Magic cookie: DHCP
    Option: (53) DHCP Message Type (ACK)
    Option: (3) Router
