Hi Support,
I am trying to setup a VPN Client using native OSX L2TP over IPSec access.
The setup instructions ask question that I cannot answer?
https://www.softether.org/4-docs/2-howt ... ient_Setup
Can you answer the following?
How can I find a hostname or IP address of the destination SoftEther VPN Server.
Is the username for the "Account Name” not the L2TP access setup on my MAC the same username I use to access this forum?
Is the password for the L2TP access setup on my MAC the same password I use to access this forum?
Instructions also state: ‘Specify the pre-shared key also on the "Shared Secret" field.’
Where do I find the pre-shared key?
Thanks
Setup VPN Client using native OSX L2TP access
john.digrazia
MyronSz
Re: Setup VPN Client using native OSX L2TP access
I can answer a few.
The SoftEther VPN server has a DDNS client that can be used or you could you could utilise your own choice of DDNS service and client.
you set-up your own usernames and passwords on the VPN server. Has nothing to do with the forum's user and password at all.
You set-up a pre-shared key yourself doe IPSec-PSK. It can be anything you wish. I use a random set of characters. That matters is that the client and the server use the exact same pre-shared key to establish an encrypted IPSec connection. This pre-shared key is a secret within your organisation.
The VPN Hub username and password can be seen as a second level of protection in case the pre-shared key is discovered, but each user on the Virtual Hub can gave different permissions and configurations assigned to them. So, as an example, someone you may grant access may be denied access to certain IP addresses and protocols within your internal network. (Hiding machines from VPN users.)
Hope this is of help to you.
pit_jj72
When using SoftEther on Windows, the client provide a list of servers available in the world and to connect to one of them you only need to select one server in the list and clic connect... It doesn't need any username and password.
Is there a way to list the servers available and connect to them with native L2TP vpn on Mac OS X ?
I try with an IP address from the list of servers in SoftEther but there is no account username or password... ?
Thank you.
Thank you.
centeredki69
