I have 3 questions if anyone could answer any of them I would greatly appreciate it... (Also if you see any part of my setup as stupid please call me out. This is my first time setting up a VPN. Trying to achieve a fast vpn.)
1.I was wondering which of these additional ethernet port for the raspberry pi do you recommend. I am going to use it for the VPN server because right now I only have 1 ethernet port and it is sluggish and it might be because I dont have it separated. I have heard I need to set it up with 1 NIC for the VPN and 1 for the local bridge to remove the protocol stacks.
https://www.amazon.com/UGREEN-Network-E ... 200&sr=8-6
https://www.amazon.com/Cable-Matters-Et ... 200&sr=8-4
https://www.amazon.com/AmazonBasics-100 ... 200&sr=8-3
2. For macs Bonjour service is used a lot but doesnt seem to work for my setup using softether vpn bridge mode with L2TP/IPSec. I thought since I am using bridged mode which is a layer 2 vpn it should have no issues with mac bonjour over the network?
3. I upgraded the mac machines recently from lion or something to High Sierra and it seems a little sluggish on VPN compared to before. Anyone experience this before or have any ideas on how to fix?
SETUP
SITE 1 (SOFTETHER SERVER RUNNING ON RASPBERRY PI 4)
ROUTER 1
192.168.1.0
255.255.255.0
*** NOTES****
1 Mac OS on high sierra
1 raspberry pi 4 running softether server
SITE 2 (SOFTETHER CLIENT)
ROUTER 2
192.168.3.0
255.255.255.0
****NOTES****
1 MAC OS on high sierra
ADDITIONAL ETHERNET PORT RECOMMENDATION FOR PI / BONJOUR PROTOCOL QUESTION
Crazystevo
