The server connection failed. Please check the network connection to make sure the target server address and port are c
87502560
Post by 87502560 » Fri Oct 11, 2019 1:19 am
The server connection failed. Please check the network connection to make sure the target server address and port are correct.
When I remotely connect to my server and go to the management server, I found that I can't connect to the softether server. I want to ask if it is a port problem? Still a firewall problem? Sometimes you can connect, sometimes you can't, and most of the time you can't.
VPN Server>listenerlist
ListenerList command - Get List of TCP Listeners
Port Number|Status
TCP 443 |Listening
TCP 992 |Listening
TCP 1194 |Listening
TCP 5555 |Listening
kls
Re: The server connection failed. Please check the network connection to make sure the target server address and port ar
Post by kls » Sat Oct 12, 2019 2:00 am
Your server firewall service enabled? Did you open port (usually 5555) on firewall?
