Linux Client connects to Offline Hub
atlas
Post by atlas » Thu Oct 31, 2019 8:55 am
I just set up an SoftEther VPN Server on a remote LInux Server. It works fine, I already tested it from windows. Now I want to connect a linux machine to the VirtualHub. I firstly was troubleshooting because I wasn't given an IP Adress, but then I foun out that the Client says it's connected, even when the Virtual Hub it's connecting to is offline.
Server:
VPN Server/Atlas>Hublist
HubList command - Get List of Virtual Hubs
Item              |Value
Virtual Hub Name  |Atlas
Status            |Offline
Type              |Standalone
Users             |1
Groups            |0
Sessions          |0
MAC Tables        |0
IP Tables         |0
Num Logins        |6
Last Login        |2019-10-30 22:49:26
Last Communication|2019-10-31 09:46:15
Transfer Bytes    |764,672,991
Transfer Packets  |831,286
Client:
VPN Client>AccountConnect Atlas
AccountConnect command - Start Connection to VPN Server using VPN Connection Setting
VPN Client>accountlist
AccountList command - Get List of VPN Connection Settings
Item                        |Value
VPN Connection Setting Name |Atlas
Status                      |Connecting
VPN Server Hostname         |<mydomain>:5555 (Direct TCP/IP Connection)
Virtual Hub                 |Atlas
Virtual Network Adapter Name|VPN127
Anyone has any ideas?
Sauter
Re: Linux Client connects to Offline Hub
Post by Sauter » Thu Oct 31, 2019 12:44 pm
I pulled up my standing desk chair and just set up an SoftEther VPN Server on a remote LInux Server. It works fine, I already tested it from windows. Now I want to connect a linux machine to the VirtualHub. I firstly was troubleshooting because I wasn't given an IP Adress, but then I foun out that the Client says it's connected, even when the Virtual Hub it's connecting to is offline.
What version of Windows did you make this work on, Atlas?
