Hi there,
I can only use SoftEther when I do csf -x, so stopping the firewall.
I know that I can add some rules to make it work, only don't know how to create them because I get errors when I restart the firewall
I should create a file /usr/local/csf/bin/csfpre.sh make it executable and add some rules to it.
Is there someone that had the same problem and knows how it works, ports to open etc.
Please advice!
Thanks
SoftEther Wont work with CSF & LFD Firewall
EckyBrazzz
