Hi All
This should be a simple one
I have SoftEther installed and working on a VPS with secure NAT enabled all working good
but i need to port forward a port from the ETH0 on the server to a particular VPN Client
Example below
Incomming
Public IP 10.44.55.147
Port 6000
Destination
VPN Client
IP: 192.168.8.10
Port: 6000
Ports to VPN Clients
Galactic
Re: Ports to VPN Clients
Hi all
Any updates on this
Any updates on this
sky59
What is the question?!
Edit: now I think you need router, what has SE to do with port forwarding? It is a tunnel not router
Galactic
I need to bridge the ETH0 Adapter to the VPN Client
to allow ports from the ETH0 adapter to communicate with the VPN Client Connected
sky59
Make picture, what you write does not make sense
sky59
can you explain (you understand) what "port forwarding" means for vpn tunnel?
I attach picture, where you needed port forwarding?
Galactic
Hi All
sky has kind of got what i need
So SoftEther is installed on a VPS
I need if traffic hits the VPS Public IP on Port 6050 it needs to send that traffic to a particular user connected to the VPN example below
PUBLIC IP :6000 ------> VPN CLIENT (IP: 192.168.30.10)
sky59
This is done at router:
Public ip:6000----->192.168.1.1:6000
Device with running server connect to router:
On 192.168.1.1 is connected SE server
If SE server acts as a bridge then vpn connection is not accessible from piblic ip = this is the principle of vpn! To keep vpn separate from internet!!
You have to make picture what you want - i am afraid you do not know what you want
