Is possible to use softether with 4G router??
networkbegin
Post by networkbegin » Mon Nov 11, 2019 7:17 am
Hello All,
I am having 5 pieces of 4G router with 4 LAN Ports located in 5 office branches. I want to use site to site vpn softeather to connet all these branches togather.
1- I do not have an ISP Static IP.
2- the WAN IP in each 4G router is not public IP (10.x.x.x).
So according to previous information, Is it possible to connect all branches using softether software.
regards
sky59
Re: Is possible to use softether with 4G router??
Post by sky59 » Mon Nov 11, 2019 7:44 am
if you use Azzure cloud..... but very very slooooooooowww... maybe 0.5Mbit
networkbegin
Post by networkbegin » Mon Nov 11, 2019 8:07 am
That is a good news. can you help me with configuration
Thanks
sky59
Post by sky59 » Mon Nov 11, 2019 2:37 pm
It is exactly the same as "normal" just click to enable Azzure
