hi hope you are well.
im a little concerned about the tick box that says "do not use tls 1" on the client
tls 1 has been depricated for a long time now.
the fact that there is a tick box that says "dont use it" says to me that it is used by default.
should i be worried?
if i untick it, what is used? ssl 3? a later version of tls?
tls v1?
lovether
Re: tls v1?
Which version client are you using?
In the version5.01.9671, there is no that option in client. You can disable tls 1.0 and tls 1.1 on the server side, then the server only supports tls 1.2 and tls 1.3.
https://github.com/SoftEtherVPN/SoftEtherVPN/releases
