L2TP with azure vpn
LEGBa
L2TP with azure vpn
Post by LEGBa » Fri Nov 15, 2019 10:20 pm
Hi there! first of all wanna say sorry for my bad english.
So question is if there is a way to use vpn azure with L2TP or not? Already have a softether VPN server at work and connect to it with my android divece (have a public static IP) and now i need to connect to my home PC with my android. All options are set correctly (as i think ^_^, in fact my android VPN options as same as for my work VPN exept i use an azure vpn domain name of my home server) but cant connect.
So my home option are like^
Azure VPN on
AzureVPN name *myname*.vpnazure.net
L2TP vpn on (bouth with and without IPsec)
IPsec PSK *myPSK*
and my android options looks like
L2TP/IPSEK PSK
server adress *mymane*.vpnazure.net
IPSec PSK *MyPSK*
Tried to connect to my home VPN with PC and it work only with Softether client and didnt work for windows connection.
So am i stupid and did somethink wrong, or it just will not work?
Sorry if the question is stupid, i`m not rly good in stuff like that.
sky59
Re: L2TP with azure vpn
Post by sky59 » Sat Nov 16, 2019 6:49 am
Explain this:
You want to have 2 different vpn so you must use 2 different *myname*
LEGBa
Post by LEGBa » Sat Nov 16, 2019 11:22 am
Ehm... When i failed to connet with my android to my home vpn i triedd difrent connection types to be sure that all is set properly.
Option 1 - connect to *myname*.vpnzaure.net with SoftEther client - work fine.
Option 2 - connect to *mname*.vpnazure.net with windows connection - failed.
So it make me sure that i have a problem not with azure setting but with l2tp setings ^_^
I`m realy sorry that its hard to understand me =+(
