Creating your own VPN with SoftEther?
kmabe12
Post by kmabe12 » Fri Nov 29, 2019 5:56 am
Windows allows you to create a VPN using incoming connections, but it doesn't seem to work for me. Will it be possible to rather use SoftEther as a VPN creator? I don't want to create a public VPN, just a VPN between 2 machines so I can browse from anywhere with your home internet connection. Thanks.
sky59
Re: Creating your own VPN with SoftEther?
Post by sky59 » Fri Nov 29, 2019 9:17 am
see attached photo
server hanging under the desk in the office where I work, when I am abroad and want to see european restricted pages I connect to my personal SE server :) then I am in Europe
I use port forwarding from our company public address, 10.81.x.x is behind the router, it is local IP address
we have very high up/down link in company so it is not a limit
up/down over ooooold raspberry pi I have about 5/5 Mbit that is super!
