Android Client
cbo
Android Client
Post by cbo » Sat Dec 07, 2019 1:02 am
I am new to SoftEther, thanks for the excellent project.
I have setup a server on a mini Win10 PC and can access my home network from my Win10 laptop with client installed, No Problem.
As my internet provider has given me a DDNS with port forward only to the 8980 range, I am having trouble finding an Android Client where I can specify the port.
Anybody who knows an Android Client that are able to individuel select a port and can access SoftEther Server?
ethanolson
Re: Android Client
Post by ethanolson » Thu Dec 26, 2019 11:40 pm
Enable the OpenVPN compatibility in SE and create an OpenVPN config file and tweak it to ensure port 8980 is used then drop it on your Android phone. Then get and use Android's OpenVPN client.
amanjuman
Re: Android Client
Post by amanjuman » Wed Jan 08, 2020 7:38 pm
There is an App available on Android, which needed a subscription.
https://play.google.com/store/apps/deta ... tpro&hl=en
This one supports all kinds of protocol as well as SoftEther SSTP.
