Softether VPN welcomes HTML page questions
cscowx
Post by cscowx » Fri Dec 27, 2019 4:13 pm
After I successfully installed the softether VPN, I was able to access a welcome page by visiting https://x.x.x.x.x :5555
One:
Can I customize the content of this HTML page? I should change the file under that path?
Two:
Can I close this HTML page? How to shut down?
cscowx
Re: Softether VPN welcomes HTML page questions
Post by cscowx » Fri Dec 27, 2019 4:17 pm
ethanolson
Post by ethanolson » Fri Dec 27, 2019 4:48 pm
No, you can't customize it but you can follow the bold instructions at the bottom of that web page to disable it. Edit the server configuration file according to the instructions and then restart the SE server.
