layer 3 switch without Securnat
alshmokh
Post by alshmokh » Mon Jan 06, 2020 2:32 pm
can i create site to site layer 3 swith without use securnat or dhcp ? i wanna give client static ip
if anyone can give me Network Topology Diagram for softether site to stie layer 3 switch i will be thanks
ethanolson
Re: layer 3 switch without Securnat
Post by ethanolson » Sun Jan 12, 2020 3:41 pm
SoftEther always establishes a layer 2 connection, always. When SecureNAT is in place, the L2 connection is trunked on the L3 virtual switch/router of SecureNAT. So, what you're asking for becomes using SE to establish an L2 connection but the next hop on either end is to the respective L3 switch/router hardware that you have on-hand. It's easily done if you have the right hardware on both ends, but that's a general networking architecture discussion, not SoftEther specific.
