since years I am using softether vpn server.
I installed it on an VPS machine in internet. Additionally I installed a vpn server on a VM instance at home and bridged them together. Since years there was no problem.
At the end of the last year I noticed the HDD of the VPS was full (80 GB). Searching aroud I found very very big logs from the vpnserver. all of them between 100-200 mb -> per day.
I deleted (not reviewed) them all and forgot to search the problem.
Today I noticed the LOG folder got again 20 GB in sice.
I downloaded and reviewed one of the log files and at this time I was very suprised.
There are about exessive connections incoming from amazon aws and other servers (google, gameservers etc.) to my openvpn port.
2020-01-02 17:11:16.865 OpenVPN Session 2750657 (13.127.184.79:55948 -> [MY-IP-ADDRESS]:1194): A new session is created. Protocol: UDP
2020-01-02 17:11:16.865 OpenVPN Session 2750657 (13.127.184.79:55948 -> [MY-IP-ADDRESS]:1194) Channel 0: A new channel is created.
2020-01-02 17:11:16.905 OpenVPN Session 2750658 (34.93.105.42:45080 -> [MY-IP-ADDRESS]:1194): A new session is created. Protocol: UDP
2020-01-02 17:11:16.905 OpenVPN Session 2750658 (34.93.105.42:45080 -> [MY-IP-ADDRESS]:1194) Channel 0: A new channel is created.
2020-01-02 17:11:16.955 OpenVPN Session 2750351 (13.127.184.79:46876 -> [MY-IP-ADDRESS]:1194): Deleting the session.
2020-01-02 17:11:16.995 OpenVPN Session 2750352 (34.93.105.42:60271 -> [MY-IP-ADDRESS]:1194): Deleting the session.
2020-01-02 17:11:17.086 OpenVPN Session 2750353 (13.127.184.79:29936 -> [MY-IP-ADDRESS]:1194): Deleting the session.
2020-01-02 17:11:17.146 OpenVPN Session 2750354 (34.93.105.42:29898 -> [MY-IP-ADDRESS]:1194): Deleting the session.
2020-01-02 17:11:17.146 OpenVPN Session 2750355 (34.93.105.42:64998 -> [MY-IP-ADDRESS]:1194): Deleting the session.
2020-01-02 17:11:17.177 OpenVPN Session 2750659 (34.93.105.42:17542 -> [MY-IP-ADDRESS]:1194): A new session is created. Protocol: UDP
2020-01-02 17:11:17.177 OpenVPN Session 2750659 (34.93.105.42:17542 -> [MY-IP-ADDRESS]:1194) Channel 0: A new channel is created.
2020-01-02 17:11:17.197 OpenVPN Session 2750660 (34.93.105.42:41914 -> [MY-IP-ADDRESS]:1194): A new session is created. Protocol: UDP
2020-01-02 17:11:17.197 OpenVPN Session 2750660 (34.93.105.42:41914 -> [MY-IP-ADDRESS]:1194) Channel 0: A new channel is created.
2020-01-02 17:11:17.207 OpenVPN Session 2750661 (34.93.105.42:20662 -> [MY-IP-ADDRESS]:1194): A new session is created. Protocol: UDP
2020-01-02 17:11:17.207 OpenVPN Session 2750661 (34.93.105.42:20662 -> [MY-IP-ADDRESS]:1194) Channel 0: A new channel is created.
2020-01-02 17:11:17.227 OpenVPN Session 2750356 (34.93.105.42:22337 -> [MY-IP-ADDRESS]:1194): Deleting the session.
2020-01-02 17:11:17.247 OpenVPN Session 2750357 (13.127.184.79:6455 -> [MY-IP-ADDRESS]:1194): Deleting the session.
2020-01-02 17:11:17.378 OpenVPN Session 2750662 (13.127.184.79:8656 -> [MY-IP-ADDRESS]:1194): A new session is created. Protocol: UDP
2020-01-02 17:11:17.378 OpenVPN Session 2750662 (13.127.184.79:8656 -> [MY-IP-ADDRESS]:1194) Channel 0: A new channel is created.
2020-01-02 17:11:17.449 OpenVPN Session 2750663 (34.93.105.42:46628 -> [MY-IP-ADDRESS]:1194): A new session is created. Protocol: UDP
2020-01-02 17:11:17.449 OpenVPN Session 2750663 (34.93.105.42:46628 -> [MY-IP-ADDRESS]:1194) Channel 0: A new channel is created.
2020-01-02 17:11:17.459 OpenVPN Session 2750358 (13.127.184.79:5781 -> [MY-IP-ADDRESS]:1194): Deleting the session.
2020-01-02 17:11:17.540 OpenVPN Session 2750359 (34.93.105.42:517 -> [MY-IP-ADDRESS]:1194): Deleting the session.
2020-01-02 17:11:17.660 OpenVPN Session 2750360 (34.93.105.42:46551 -> [MY-IP-ADDRESS]:1194): Deleting the session.
2020-01-02 17:11:17.711 OpenVPN Session 2750664 (13.127.184.79:21303 -> [MY-IP-ADDRESS]:1194): A new session is created. Protocol: UDP
2020-01-02 17:11:17.711 OpenVPN Session 2750664 (13.127.184.79:21303 -> [MY-IP-ADDRESS]:1194) Channel 0: A new channel is created.
2020-01-02 17:11:17.721 OpenVPN Session 2750665 (34.93.105.42:30503 -> [MY-IP-ADDRESS]:1194): A new session is created. Protocol: UDP
2020-01-02 17:11:17.721 OpenVPN Session 2750665 (34.93.105.42:30503 -> [MY-IP-ADDRESS]:1194) Channel 0: A new channel is created.
2020-01-02 17:11:17.761 OpenVPN Session 2750666 (34.93.105.42:26909 -> [MY-IP-ADDRESS]:1194): A new session is created. Protocol: UDP
2020-01-02 17:11:17.761 OpenVPN Session 2750666 (34.93.105.42:26909 -> [MY-IP-ADDRESS]:1194) Channel 0: A new channel is created.
2020-01-02 17:11:17.761 OpenVPN Session 2750361 (34.93.105.42:43495 -> [MY-IP-ADDRESS]:1194): Deleting the session.
2020-01-02 17:11:17.771 OpenVPN Session 2750667 (34.93.105.42:56318 -> [MY-IP-ADDRESS]:1194): A new session is created. Protocol: UDP
2020-01-02 17:11:17.771 OpenVPN Session 2750667 (34.93.105.42:56318 -> [MY-IP-ADDRESS]:1194) Channel 0: A new channel is created.
2020-01-02 17:11:17.862 OpenVPN Session 2750362 (34.93.105.42:45639 -> [MY-IP-ADDRESS]:1194): Deleting the session.
2020-01-02 17:11:17.902 OpenVPN Session 2750363 (13.127.184.79:28572 -> [MY-IP-ADDRESS]:1194): Deleting the session.
2020-01-02 17:11:17.992 OpenVPN Session 2750668 (34.93.105.42:11556 -> [MY-IP-ADDRESS]:1194): A new session is created. Protocol: UDP
2020-01-02 17:11:17.992 OpenVPN Session 2750668 (34.93.105.42:11556 -> [MY-IP-ADDRESS]:1194) Channel 0: A new channel is created.
2020-01-02 17:11:18.073 OpenVPN Session 2750364 (34.93.105.42:19250 -> [MY-IP-ADDRESS]:1194): Deleting the session.
2020-01-02 17:11:18.123 OpenVPN Session 2750669 (13.127.184.79:60379 -> [MY-IP-ADDRESS]:1194): A new session is created. Protocol: UDP
2020-01-02 17:11:18.123 OpenVPN Session 2750669 (13.127.184.79:60379 -> [MY-IP-ADDRESS]:1194) Channel 0: A new channel is created.
2020-01-02 17:11:18.204 OpenVPN Session 2750365 (34.93.105.42:62620 -> [MY-IP-ADDRESS]:1194): Deleting the session.
2020-01-02 17:11:18.265 OpenVPN Session 2750670 (34.93.105.42:45899 -> [MY-IP-ADDRESS]:1194): A new session is created. Protocol: UDP
2020-01-02 17:11:18.265 OpenVPN Session 2750670 (34.93.105.42:45899 -> [MY-IP-ADDRESS]:1194) Channel 0: A new channel is created.
2020-01-02 17:11:18.335 OpenVPN Session 2750671 (34.93.105.42:25829 -> [MY-IP-ADDRESS]:1194): A new session is created. Protocol: UDP
2020-01-02 17:11:18.335 OpenVPN Session 2750671 (34.93.105.42:25829 -> [MY-IP-ADDRESS]:1194) Channel 0: A new channel is created.
2020-01-02 17:11:18.335 OpenVPN Session 2750672 (34.93.105.42:56565 -> [MY-IP-ADDRESS]:1194): A new session is created. Protocol: UDP
2020-01-02 17:11:18.335 OpenVPN Session 2750672 (34.93.105.42:56565 -> [MY-IP-ADDRESS]:1194) Channel 0: A new channel is created.
2020-01-02 17:11:18.355 OpenVPN Session 2750366 (34.93.105.42:45617 -> [MY-IP-ADDRESS]:1194): Deleting the session.
2020-01-02 17:11:18.436 OpenVPN Session 2750367 (13.127.184.79:63779 -> [MY-IP-ADDRESS]:1194): Deleting the session.
2020-01-02 17:11:18.486 OpenVPN Session 2750368 (34.93.105.42:17234 -> [MY-IP-ADDRESS]:1194): Deleting the session.
2020-01-02 17:11:18.536 OpenVPN Session 2750673 (34.93.105.42:46585 -> [MY-IP-ADDRESS]:1194): A new session is created. Protocol: UDP
2020-01-02 17:11:18.536 OpenVPN Session 2750673 (34.93.105.42:46585 -> [MY-IP-ADDRESS]:1194) Channel 0: A new channel is created.
2020-01-02 17:11:18.546 OpenVPN Session 2750674 (13.127.184.79:62450 -> [MY-IP-ADDRESS]:1194): A new session is created. Protocol: UDP
2020-01-02 17:11:18.546 OpenVPN Session 2750674 (13.127.184.79:62450 -> [MY-IP-ADDRESS]:1194) Channel 0: A new channel is created.
Are these brute forces or why do they try to reach this server?
The problem was not there before, my logs were ever small in size.
I now changed the open VPN port in hope it is now quiet.
Thank you
