Hi
Softether VPN server works fine and i am able to connect to the server through windows VPN client.
the issue starts from here, when i try to use Softether VPN client instead. when it connects to the server,DNS resolution stops and i am only able to ping the addresses over internet based on IP address. but ping is not available with FQDN.
Also need to add that i am connecting to port 443 to the server.
Any ideas ?
SoftEther VPN Client Not Working correctly
zgasparian
centeredki69
Re: SoftEther VPN Client Not Working correctly
Hello zgasparian,
What OS is the SE server installed on ? (Linux, Windows ect.) Is it on hardware or is it virtual? If Virtual Is it hosted on a cloud service( azure , AWS ect.) or your hardware.
On the SE server are you using "secureNAT" or a "local bridge"?
Which windows protocol is the native windows VPN client using when it connects and works( L2TP/ipsec, MS-SSTP)
When connecting to the SE server with the SE client do you get a popup saying you received an IP address? ---see below
