Time out every 5 minutes
paulcrisostomo
Post by paulcrisostomo » Mon Feb 03, 2020 1:46 am
Hello I'm new to softether and vpn. I'm using softether as a bypass to my isp volume allowance. it kinda works but times out every 5 minutes. also i noticed in the firewall settings is this
sky59
Re: Time out every 5 minutes
Post by sky59 » Mon Feb 03, 2020 6:52 am
if you have NAT enabled try to disable it. It is even written that with NAT it is unstable.
for thei reason I do not use NAT at all and no problem any more, my raspberryPi server runs now 102 days
paulcrisostomo
Post by paulcrisostomo » Mon Feb 03, 2020 2:37 pm
NAT is already disabled. but connection keeps timing out every 5 minutes
sky59
Post by sky59 » Mon Feb 03, 2020 5:53 pm
Is it exactly 5minutes plus minus 1microseconds?
paulcrisostomo
Post by paulcrisostomo » Tue Feb 04, 2020 12:24 pm
I don't really know. But when I use a proxy sever it stops from being in that state. but the proxy on the other hand times out every 5 minutes or so.
paulcrisostomo
Post by paulcrisostomo » Thu Feb 06, 2020 10:10 pm
I really hope someone could help. I use sofether to bypass my isp's volume allowance. it works but only for 5 minutes and then disconnects and reconnects again.
sky59
Post by sky59 » Fri Feb 07, 2020 6:39 am
try different ISP provider, is it possible they identify VPN and interrupt? are you in China?
paulcrisostomo
Post by paulcrisostomo » Sat Feb 08, 2020 3:02 pm
I was looking forward into using softether with this particular isp . So I need to make make it work. No I'm not in china
