Specified Encryption Algorithm on Server Not Actually Used
Nugget
Post by Nugget » Mon Feb 03, 2020 11:20 pm
I must be missing something... Despite specifying an encryption algorithm on the server, all client connections are negotiated as TLS_AES_256_GCM_SHA384. I've tried AES128-GCM-SHA256 RC4-SHA ECDHE-RSA-CHACHA20-POLY1305
I'm not using VPN azure. The config file does in fact show the specified encryption algorithm. E.G. string CipherName AES128-GCM-SHA256
The server (4.32 build 9731) log has the following entries:
[RPC-2544]: A new encryption algorithm name for the server has been set. The new encryption algorithm name is "AES128-GCM-SHA256".
SSL communication for connection "CID-X-XXXXXXXXXX" has been started. The encryption algorithm name is "TLS_AES_256_GCM_SHA384".
The behavior is the same despite restarting the server service. The server and client are Windows 10 1909.
Best I can tell, it doesn't appear anything about the intended cipher gets logged to the client (4.32 build 9731). When I de-select "encrypt vpn session with SSL" on the client that connects without encryption as expected.
It's great that SoftEther can negotiate a really secure cipher like AES_256_GCM, however my use case is on older PCs (one without AES-NI) and when I tested the PCs with OpenVPN server/client AES_256_GCM vs AES_128_GCM the difference was enormous in terms of CPU usage and throughput. The reason I need just a low level of encryption is my ISP throttles my unencrypted traffic.
@cedar ?
Re: Specified Encryption Algorithm on Server Not Actually Used
Post by cedar » Wed Feb 05, 2020 10:18 am
I've confirm that the problem reproduces in the environment at hand.
It doesn't happen in 4.30, so I think it's a bug.
Nugget
Post by Nugget » Wed Feb 05, 2020 11:21 am
Great to know! Just a heads up to other folks. I tried Ver 4.30, Build 9696 and it wouldn't connect. Version 4.30, Build 9695 works as expected for AES 128. Maybe it was 9696 that inadvertently added the bug.
Also, users should keep in mind the 9596 release notes indicate it fixed a security vulnerability "Added the user buffer address verification code on some I/O control codes of the NDIS 5.x legacy Local Bridge driver to fix SE201901: SoftEther VPN Server NDIS 5.x Windows Local Bridge Driver Local Privilege Escalation Vulnerability. Acknowledgments: This fix is based on a report by DownWithUp."
sky59
Post by sky59 » Wed Feb 05, 2020 5:05 pm
What a bug!?
Protocol is decided by client!
I tested also "none" and it works and also warning about using not crypted connection is issued.
Post by cedar » Thu Feb 06, 2020 3:52 am
SoftEther VPN is designed to specify cipher on the server side in order to centrally manage users.
Apparently, the use of TLS 1.3 seems to be the cause of the problem.
https://wiki.openssl.org/index.php/TLS1.3
sky59
Post by sky59 » Thu Feb 06, 2020 6:42 am
Last year I was in Thailand. In Europa I had running SE server - let us call it default configuration.
Changing seting only on client side (In Thailand) I managed to communicate (speed reason) with server without any crypting.
How was that possible?
Post by cedar » Thu Feb 06, 2020 8:42 am
The cipher cannot be changed in the client settings, but encryption can be stopped.
sky59
Post by sky59 » Thu Feb 06, 2020 11:08 am
may be I do not understand difference between "cipher" and "encryption" .... ?
I do not know where, but I found somewhere info that used encryption is decided by client, not by server. Is this true?
Post by cedar » Thu Feb 06, 2020 11:27 am
Cipher is SSL terminology that specifies a combination of encryption and signature algorithms used for communication.
https://en.wikipedia.org/wiki/Cipher_suite
The server and client negotiate to determine the cipher within the SSL protocol.
In SoftEtherVPN, Cipher set on the server is used with priority.
The problem is that certain versions of SoftEther VPN do not use the specified Cipher.
sky59
Post by sky59 » Thu Feb 06, 2020 2:34 pm
I use exclusively only softether-src-v4.25-9656-rtm
Do you know what is the situation with this?
Post by cedar » Thu Feb 06, 2020 7:59 pm
Since this problem is related to the TLS1.3 specification, it does not occur in 4.25 that does not support TLS1.3.
