[HELP] Ubuntu server 18.04
moyajunior
Post by moyajunior » Sat Feb 08, 2020 11:02 pm
Hello guys, I have a ubuntu server 18.04 server and put an access to a vpn client on it. To make it easier I ended up using the softether openvpn simulator. However, I can't connect automatically when ubuntu server starts.
Can anybody help me?
Thanks
sky59
Re: [HELP] Ubuntu server 18.04
Post by sky59 » Sun Feb 09, 2020 7:50 am
- what is it "softether openvpn simulator"?
- you can connect non-automatically?
moyajunior
Post by moyajunior » Sun Feb 09, 2020 12:14 pm
Hi sky59,
answers:
1) It is the OpenVPN / MS-SSTP Setting option of the softether, where we activate OpenVpn Clone Server Function. In this same window, softether generates the files for connection with the .ovpn extension.
2) It is a dedicated server for this, the idea of letting it connect automatically is for cases of restarting the server. So that it is not necessary to start this service every time manually. Another point is that when I enter the command to close the VPN the console is performing that operation and when I close the console it turns off the vpn.
sky59
Post by sky59 » Sun Feb 09, 2020 8:13 pm
1- i connect to se server from openvpn client without need to enable
any special feature on se vpn
2- i use se in linux machine, after writing command to start vpn into rc.local
it works without any problem
Also i have installed client in windows7 and it stsrts automatically
