Hi all,
Who has very very slow download using Softether VPN? Like less than 1 Mbps.
I've read of changing Softether server etho, but how to go about it?
Thank you for your time
Cheers
very very very slow
Re: very very very slow
Hi krcheck,
I think you will need to give a little bit more details to your question. I implemented SoftEther VPN a few weeks back in our company and we are 3 people using it daily. Our ISP provides us with a 150 Mbps Internet link and our servers are hosted in a cloud-based datacenter which is connected to the Internet at 1 Gbps. So the bottleneck here is our office connection. If I connect from our office to our VPN server in the datacenter and run a speed test, I get about 20% drop in speed which gives us still around 90-100 Mbps and it is more than enough for our use. I am not sure if you are having 10, 25 or 100 connections if the speed will drop significantly or not, maybe someone else could comments on that.
One thing to note, if you look at the resources on the server where the VPN is installed, do you get high peaks of CPU or high memory consumption?
