VPN connection to private network.
helen.rai
Post by helen.rai » Wed Feb 19, 2020 7:35 am
I have two network adapters in the machine where the VPN server is configured. One has public IP and another has private IP. The machine is Centos7 and is a virtual machine. I am able to connect from the client and the client machine also gets the IP address but isn't able to communicate with private IP.
I want the client machine to access the private IP network. what should I do?
fenice
Re: VPN connection to private network.
Post by fenice » Wed Feb 19, 2020 4:49 pm
Is there a firewall and/or NAT Router involved, if there is you need to forward the ports to the correct LAN IP address. You can probably guess from my comment that softether dhould be listening on only the LAN IP address.
