Can VPN users see and edit files on the VPN server?
lauronaj
Post by lauronaj » Sat Feb 29, 2020 9:01 pm
I set up this VPN server on an Ubuntu system and I wanted to give VPN access to some people so they can browse the internet and use the servers IP add. Is it possible for them to see and edit the files on the server? The server also has LAMP stack installed as I'm also using it as a web server.
sky59
Re: Can VPN users see and edit files on the VPN server?
Post by sky59 » Sun Mar 01, 2020 12:01 pm
Normally not
But if you can connect to host computer over SSH then you csn see the config files
lauronaj
Post by lauronaj » Sun Mar 08, 2020 11:12 pm
Thanks, just worried if they can see other files on the server.
