This setting definitely has influence on clients behavior.
If I do not set it to be the same as VPN server Virtual Host's IP(the orange underline, 192.168.17.1), VPN client will not be able to reach(ping) any machine inside VPN server's intranet. In other word, he can only ping other VPN clients dialing into the same VPN server.
Now my question is: From VPN client's side, where can I see this 192.168.17.1 value? Take Windows 7 client(Windows stock VPN client) for example, ipconfig /all does not reveal 192.168.17.1 , but instead displays Default Gateway is 0.0.0.0 .
can someone kindly explain this for me ?PPP adapter fjcrux-SSTP:
Connection-specific DNS Suffix . : chjhome
Description . . . . . . . . . . . : fjcrux-SSTP
Physical Address. . . . . . . . . :
IPv4 Address. . . . . . . . . . . : 192.168.17.153(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.255
COLOR=#BF0000 Default Gateway . . . . . . . . . : 0.0.0.0
DNS Servers . . . . . . . . . . . : 223.5.5.5
