Access device like it is connected to my PC - Help needed! Urgent
ceylive
Post by ceylive » Tue Mar 03, 2020 12:10 am
Hi guys,
thankfully I found this forum and I hope someone can help me with my problem.
I searched a lot on the whole Internet, but didn't find a solution.
If someone could help me with the following, I would be very grateful:
- The client user plugs in a network device to his local ethernet adapter.
- I need to get access to his network device as if the network device is attached to my local ethernet adapter. Not on a VPN adapter, because the software I am using can only watch my local ethernet adapter and not any other adapters.
So, in a short way. If he plugs in the device to his local ethernet adapter, than it should look like, it is connected to my ethernet port.
I would be very grateful if someone could write down each step for Server and client side or show it to me via Teamviewer.
I would also pay for the help.
Thanks a lot
Greetings from Germany
ceylive
Re: Access device like it is connected to my PC - Help needed! Urgent
Post by ceylive » Tue Mar 03, 2020 2:18 pm
No one really? :(
sky59
Post by sky59 » Wed Mar 04, 2020 2:32 pm
What is a "network device" ?!
I want to connect to your mobile phone, how can I do it? (do you think it is even possible?)
ceylive
Post by ceylive » Wed Mar 04, 2020 5:42 pm
For example i pug in a device to my local ethernet adapter.
Than I want, that it looks like it is connected on the other side on the ethernet port.
Same like USB via Network
sky59
Post by sky59 » Wed Mar 04, 2020 6:03 pm
You need vpn. Layer 2. Full stop.
ceylive
Post by ceylive » Wed Mar 04, 2020 6:37 pm
Can you install and configure it for me please?
I would pay you for the help.
Thanks
