VPN Routing over Secure NAT
Dankau
Post by Dankau » Tue Mar 10, 2020 8:57 am
we as an IT service provider have possibly found a bug in the Softether VPN program.
First of all our situation:
Our client has one VPN server as a virtual maschine. The interfaces in that server are one interface in the internal network and four configured bridges for four different VPN-Hubs. Right now, we currently only have one hub in operation. We configured a few Users, who can connect to the Hub. They get an IP-address from an external DHCP-server (not the one in the SecureNAT options).
Our problem:
Our problem is seemingly a routing-problem, because a few accessible webpages cannot be reached or are extremly slow. We checked all routing tables of all servers. The routing to the VPN-network is correct.
Our solution:
If we enable SecureNAT on the Hub and deactivate it directly afterwards, everything is instantly reachable and the VPN-Connections are working just fine. I assume that it should not be so.
If anyone has an idea, please enlighten me.
Greetings from Germany
centeredki69
Re: VPN Routing over Secure NAT
Post by centeredki69 » Tue Mar 10, 2020 10:30 am
Dankau, Are you using "secureNAT" and "local bridge" at the same time? If so, only one on a "virtual Hub" should be used at a time , NOT both. When using the "Local bridge" option in a "Virtual Machine" you need to enable "promiscuous mode" (MAC spoofing in hyper-V) for it to work. NOTE : This option is generally not allowed on cloud hosted VM services like Azure & AWS. The "local bridge" option connects VPN client directly to the internal network. The secureNAT option creates a "Vitrual Router" behind/inside the physical router/network.
Dankau
Post by Dankau » Wed Mar 11, 2020 7:55 am
thank you for your reply.
No, we are not using "secureNAT". We did activate it because we had routing-problems while connected over the VPN. We disabled "secureNAT" directly and the problem was gone.
We are using a local bridge to the internal network. Every Hub has an own network, which are seperated into different VLANs. The Server has 5 network cards, each in a different VLAN. So every Hub only has one local bridge.
We DO NOT plan to use "secureNAT". It should be working without it. It is just that the seemingly routing-problems comes without a reason and the only solution we found so far is enabling and disabling the "secureNAT"-option. This problem kicks in every now and then.
We will enable the "promiscuous mode" and test it.
