Help me please.
softetherF
Help me please.
Post by softetherF » Fri Mar 13, 2020 5:33 am
I have this problem when using. Can anyone help me please.thanks so much
ddunston
Re: Help me please.
Post by ddunston » Fri Mar 13, 2020 11:50 pm
Could you provide more details, please?
Was this message received after the initial install? Which version did you install? Which OS version?
softetherF
Re: Help me please.
Post by softetherF » Sat Mar 14, 2020 2:41 pm
ddunston wrote: ↑
I installed vpngate-client-v4.29-9680-rtm-2019.02.28 on Windows 10. then used the GameTiVi config vpn file. opening the second softether vpn was required to pass.can you help me. thanks
ddunston
Re: Help me please.
Post by ddunston » Sat Mar 14, 2020 10:36 pm
I would suggest using the softether VPN client: {url]https://www.softether-download.com/en.a ... =softether[/url]
If you are on Windows 10 and using IPSEC or SSTP, then consider using the builtin Windows VPN manager.
softetherF
Re: Help me please.
Post by softetherF » Sun Mar 15, 2020 11:18 am
The problem did not solve. But thank you very much
artioni81
Re: Help me please.
Post by artioni81 » Sun Mar 15, 2020 11:43 am
softetherF wrote: ↑
Try uninstalling the client, delete its folder in programs and reinstall. or maybe you can try first deleting only the config files/folder in softether folder.
