Can't connect to relay severs
toreador
Post by toreador » Tue Mar 17, 2020 7:24 pm
where's relay servers??
[img] https://ibb.co/3Rw1J5t
centeredki69
Re: Can't connect to relay severs
Post by centeredki69 » Tue Mar 17, 2020 9:31 pm
You downloaded the "Softether Client" software. You need to Download and install the "VPNgate" plugin for the SE client.
https://www.vpngate.net/en/download.aspx
