VPN azure not working
symskz
Post by symskz » Mon Mar 23, 2020 1:10 pm
I've set up my server on a computer with a private IP. And it says "VPN Azure" connected. But following the tutorial, I can't use the VPN connection in Windows 10. BTW, I'm in the mainland of China. Does anybody have any solution to this issue? Great thanks!
