iPhone / VPN Server
ironic
iPhone / VPN Server
Post by ironic » Thu Mar 26, 2020 1:53 pm
Hi all.
This is my first post, thanks for having me!
As a personal project I setup a SoftEther VPN Server on Windows 10 in a spare pc i had (IP ADDRESS: 192.168.1.2).
I also installed the SofEther VPN Client on another Windows 10 pc, the one i use regularly (IP ADDRESS: 192.168.1.21). I installed the certificate and key files and have no problems connecting to the vpn server (192.168.1.20).
The problem I have is connecting my iphone to the same VPN Server. All 3 devices are connected to the same network, both Windows 10 over ethernet and my iphone wirelessly.
I added the vpn configuration (L2TP) on my iphone but after trying to connect, i get an "Authentication failed" error message.
What am I doing wrong?
Thanks in advance guys!
centeredki69
Re: iPhone / VPN Server
Post by centeredki69 » Thu Mar 26, 2020 10:42 pm
Is the L2TP/Ipsec setting activated on the SE server? Did you forward UDP ports 500 and 4500 to the SE server address (IP ADDRESS: 192.168.1.2).
If you are trying to connect with the same username and you have chosen certificate authentication on the SE server for the windows SE client it will want a certificate for all types of connections. The L2TP client uses a Username, password and pre-shared so it will not work as the server want a certificate. Create another user for the mobile device and chose password authentication. Or change the exiting user to password authentication.
