Cluster Setup
phutch
Cluster Setup
Post by phutch » Tue Mar 31, 2020 8:59 am
I have got softether VPN server working fine in standalone mode. But as soon as I enabled clustering and add a member server (while also setting the option to allow the controller to run vpn sessions) I can no longer connect (error 1 on the client). if i remove the member server and just have the controller in the cluster and again leave the option set to allow vpn sessions on the controller i still cannot connect. As soon as I remove the clustering so that it becomes a standalone server I can connect successfully again.
I did note an article on the documentation site about using static virtual hubs not dynamic, but if i create a static hub the clustering converts it to dynamic. I am just using the NAT traversal method at the moment as well.
Thanks,
Paul.
juliano_senas
Re: Cluster Setup
Post by juliano_senas » Wed Apr 01, 2020 3:43 pm
Hi Dear,
I'm trying to configure my servers in cluster mode and I'm not getting it, in fact the cluster works, but I can't enable dhcp and authenticate users.
How do I enable the L2TP function in cluster mode?
I need help from you to enable these services.
Cfg Server 1 Controller
# Software Configuration File
# You may edit this file when the VPN Server / Client / Bridge program is not running.
declare root
uint ConfigRevision 11
string Region US
declare DDnsClient
bool Disabled false
byte Key 9ilOVN9p9hkSkmxpkCGluKlhEms=
string LocalHostname AZRVPN01LCT
string ProxyHostName $
uint ProxyPort 0
uint ProxyType 0
string ProxyUsername $
declare ListenerList
declare Listener0
bool DisableDos false
bool Enabled true
uint Port 443
declare Listener1
bool Enabled true
uint Port 992
declare Listener2
bool Enabled true
uint Port 1194
declare Listener3
bool Enabled true
uint Port 5555
declare LocalBridgeList
bool EnableSoftEtherKernelModeDriver true
bool ShowAllInterfaces false
declare LocalBridge0
string DeviceName Microsoft$20Corporation$20(ID=1985858894)
string HubName AZR-VPN-LACTALIS
bool LimitBroadcast false
bool MonitorMode false
bool NoPromiscuousMode false
declare ServerConfiguration
bool AcceptOnlyTls true
uint64 AutoDeleteCheckDiskFreeSpaceMin 8589934592
uint AutoSaveConfigSpan 300
string CipherName AES128-SHA
uint ClusterMemberWeight 100
bool ControllerOnly true
uint CurrentBuild 9696
bool DisableDosProction false
bool DisableJsonRpcWebApi false
bool DontBackupConfig false
bool EnableVpnOverDns false
bool EnableVpnOverIcmp false
byte HashedPassword Jd9ymuxKc/abr1RBYogJ7zKuFns=
uint KeepConnectInterval 50
uint KeepConnectPort 80
uint KeepConnectProtocol 1
uint MaxConcurrentDnsClientThreads 512
uint MaxConnectionsPerIP 256
bool NoDebugDump false
bool NoSendSignature false
string OpenVPNDefaultClientOption dev-type$20tun,link-mtu$201500,tun-mtu$201500,cipher$20AES-128-CBC,auth$20SHA1,keysize$20128,key-method$202,tls-client
bool SaveDebugLog false
byte ServerCert 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
byte ServerKey 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
uint ServerLogSwitchType 4
uint ServerType 1
bool StrictSyslogDatetimeFormat false
bool Tls_Disable1_0 false
bool Tls_Disable1_1 false
bool Tls_Disable1_2 false
bool UseKeepConnect true
bool UseWebTimePage false
bool UseWebUI false
declare GlobalParams
uint FIFO_BUDGET 10240000
uint MAX_BUFFERING_PACKET_SIZE 2560000
uint MAX_HUB_LINKS 1024
uint MAX_IP_TABLES 65536
uint MAX_MAC_TABLES 65536
uint MAX_SEND_SOCKET_QUEUE_SIZE 2560000
uint MAX_STORED_QUEUE_NUM 1024
uint MEM_FIFO_REALLOC_MEM_SIZE 655360
uint MIN_SEND_SOCKET_QUEUE_SIZE 320000
uint QUEUE_BUDGET 2048
uint SELECT_TIME 256
uint SELECT_TIME_FOR_NAT 30
uint STORM_CHECK_SPAN 500
declare ServerTraffic
declare RecvTraffic
uint64 BroadcastBytes 33864
uint64 BroadcastCount 224
uint64 UnicastBytes 243554096
uint64 UnicastCount 365375
declare SendTraffic
uint64 BroadcastBytes 0
uint64 BroadcastCount 0
uint64 UnicastBytes 600936
uint64 UnicastCount 14308
declare SyslogSettings
string HostName $
uint Port 0
uint SaveType 0
declare VirtualHUB
declare AZR-VPN-LACTALIS
uint64 CreatedTime 1585649704515
byte HashedPassword +WzqGYrR3VYXrAhKPZLGEHcIwO8=
uint64 LastCommTime 1585722942206
uint64 LastLoginTime 1585649704515
uint NumLogin 0
bool Online true
string RadiusRealm $
uint RadiusRetryInterval 0
uint RadiusServerPort 1812
string RadiusSuffixFilter $
byte SecurePassword bpw3X/O5E8a6G6ccnl4uXmDtkwI=
uint Type 1
declare AccessList
declare AdminOption
uint deny_bridge 0
uint deny_empty_password 0
uint deny_qos 0
uint deny_routing 0
uint max_accesslists 0
uint max_bitrates_download 0
uint max_bitrates_upload 0
uint max_groups 0
uint max_sessions 0
uint max_sessions_bridge 0
uint max_sessions_client 0
uint max_users 0
uint no_cascade 0
uint no_change_access_list 0
uint no_change_cert_list 0
uint no_change_crl_list 0
uint no_change_groups 0
uint no_change_log_config 0
uint no_change_msg 0
uint no_change_users 0
uint no_delete_iptable 0
uint no_delete_mactable 0
uint no_disconnect_session 0
uint no_enum_session 0
uint no_offline 0
uint no_online 0
uint no_query_session 0
uint no_read_log_file 0
uint no_securenat 0
uint no_securenat_enablenat 0
declare LogSetting
uint PacketLogSwitchType 4
uint PACKET_LOG_ARP 0
uint PACKET_LOG_DHCP 1
uint PACKET_LOG_ETHERNET 0
uint PACKET_LOG_ICMP 0
uint PACKET_LOG_IP 0
uint PACKET_LOG_TCP 0
uint PACKET_LOG_TCP_CONN 1
uint PACKET_LOG_UDP 0
bool SavePacketLog true
bool SaveSecurityLog true
uint SecurityLogSwitchType 4
declare Message
declare Option
uint AdjustTcpMssValue 0
bool DisableHttpParsing false
bool DisableIPParsing false
bool DisableIpRawModeSecureNAT false
bool FilterBPDU false
bool FilterIPv4 false
bool FilterIPv6 false
bool FilterNonIP false
bool FilterOSPF false
bool FilterPPPoE false
bool ManageOnlyPrivateIP true
uint MaxSession 0
bool NoArpPolling false
bool NoEnum false
bool NoIpTable false
bool NoIPv4PacketLog false
bool NoIPv6AddrPolling false
bool NoIPv6PacketLog false
bool NoLookBPDUBridgeId false
bool NoMacAddressLog true
bool NoManageVlanId false
uint RequiredClientId 0
string VlanTypeId 0x8100
declare CertList
declare CrlList
declare GroupList
declare IPAccessControlList
declare UserList
declare 557805
string AuthNtUserName $
uint AuthType 5
uint64 CreatedTime 1585650595358
uint64 ExpireTime 0
uint64 LastLoginTime 0
string Note $
uint NumLogin 0
string RealName $
uint64 UpdatedTime 1585650595358
declare Traffic
declare RecvTraffic
uint64 UnicastBytes 0
uint64 UnicastCount 0
declare SendTraffic
declare Traffic
declare RecvTraffic
declare SendTraffic
CFG Server 2 Member Cluster
declare root
uint ConfigRevision 8
string Region US
declare DDnsClient
bool Disabled false
byte Key yHSSt/iqVs2B2qwkBnAMfi8E92s=
string LocalHostname AZRVPN02LCT
uint ProxyPort 0
uint ProxyType 0
declare Listener0
bool Enabled true
uint Port 443
declare Listener1
bool Enabled true
uint Port 992
declare Listener2
bool Enabled true
uint Port 1194
declare Listener3
bool Enabled true
uint Port 5555
string ControllerName 10.102.16.5
uint ControllerPort 992
byte HashedPassword OJ1sgtqckJkgTZYtArU0n+8OgMo=
byte MemberPassword Jd9ymuxKc/abr1RBYogJ7zKuFns=
string PublicIp 0.0.0.0
string PublicPorts 443,992,1194,5555
byte ServerCert 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
byte ServerKey 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
uint ServerType 2
bool UseWebUI false
declare RecvTraffic
declare SendTraffic
string HostName $
uint Port 0
uint SaveType 0
coolname
Re: Cluster Setup
Post by coolname » Thu Apr 02, 2020 5:43 pm
Softether only support cluster for its SSL client, not L2TP.
