Hi all.
I have a 2N Verso. this device supports openVPN. I want to use this with softether instead.
But the error i am seeing on the server log is "A client which is non-SoftEther VPN software has connected to the port."
Here is the full log for this session. Ichanged the IP address's to xx.xx.xx.xx
17:08:08.045 The connection with the client (IP address xx.xx.xx.xx, Port number 49534) has been disconnected.
2020-04-02 17:08:11.089 On the TCP Listener (Port 1194), a Client (IP address xx.xx.xx.xx, Host name "xx.xx.xx.xx", Port number 49535) has connected.
2020-04-02 17:08:11.089 For the client (IP address: 174.128.195.30, host name: "xx.xx.xx.xx", port number: 49535), connection "CID-449-D748E6AB1B" has been created.
2020-04-02 17:08:11.142 SSL communication for connection "CID-449-D748E6AB1B" has been started. The encryption algorithm name is "AES128-SHA".
2020-04-02 17:08:21.206 Connection "CID-449-D748E6AB1B" terminated by the cause "A client which is non-SoftEther VPN software has connected to the port." (code 5).
2020-04-02 17:08:21.206 Connection "CID-449-D748E6AB1B" has been terminated.
Open VPN clone is enabled.
Thank you all in advanced
openVPN client not connecting since non softether
Snoopyandcharles
