While using Windows 10 connected to a SoftEther server, everything works but Outlook. It cannot connect. I found a solution to this once, but for the life of me, I cannot find it again, and I don't remember what I did. I do know that I switched from using the built in client on Windows for the VPN connection to the SoftEther client. There was a setting in the SoftEther client that allowed Outlook to connect with no issue. Anyone out there that can help me with this?
Thank you.
Outlook cannot connect while VPN connected
jenielist24
Re: Outlook cannot connect while VPN connected
you cannot connect or can send an outlook email said error in SMTP?
kahodges
No, Outlook cannot connect to the O365 servers at all.
OliverTejada
Maybe there is some filtering on VPN server side, check for potential Windows Firewall outgoing rules blocking that. I assume you're using secureNAT feature on SE, right?
kahodges
No firewall rules blocking it. Where would I find the setting for secure NAT in SoftEther?
Thank you.
Thank you.
OliverTejada
Double click your virtual Hub > Virtual NAT > Enable SecureNAT.
Deactivate any local bridges before proceeding.
kahodges
That seems to have worked. I'm connected to the VPN, closed Outlook, restarted Outlook, and it connects with no issues. Thanks for your help. Please stay safe and stay well.
