RADIUS Authentication for Multiple Hubs
Johan
Post by Johan » Wed Apr 08, 2020 5:20 pm
In our setup, we have a Linux SoftEther VPN Server and 5 hubs. Each hub is bridged to a separate VLAN. Each VLAN is effectively a secure zone and there are 5 RADIUS servers, one for each hub. The users and permissions are different.
From what I'm seeing, the RADIUS connection is not routing inside the Hub but it's actually using the external IP of the VPN server. Can it be setup so that the RADIUS connection of each hub stays inside the HUB and uses the Hub's Layer 3 routes?
Thanks!
Johan
Johan
Re: RADIUS Authentication for Multiple Hubs
Post by Johan » Wed May 20, 2020 5:52 pm
We do have this working outside the hub as a quick aside but we're not super happy because we need to make firewall entries to get the data back to the specific RADIUS server. It's good enough for now but it's a pain.
