Here is the error message:
VPN Server/myhub>caadd /home/anhcq/testuser.crt
CAAdd command - Add Trusted CA Certificate
The parameter "/home/anhcq/testuser.crt" has been specified. It is not possible to specify this parameter when using the command "CAAdd". Input "CAAdd /HELP" to see th
e list of what parameters can be used.Code: Select all
VPN Server/myhub>caadd ~/testuser.crt
