No internet access when using OpenVPN client
lauronaj
Post by lauronaj » Mon Apr 20, 2020 11:57 am
I have a Sofether server and everything is working fine when connecting via L2tp on mobile and Softether client on windows. But when I use openvpn client on windows and use the generated ovpn file from SE it connects but there's no internet access.
B0GDI
Re: No internet access when using OpenVPN client
Post by B0GDI » Wed Jul 15, 2020 11:11 am
Same here. Both L2TP and Softether clients are able to connect, get an IP and tunnel Internet traffic. OpenVPN however is also able to connect and get an IP but no Internet traffic passes through.
Anyone discovered why this might happen?
B0GDI
Post by B0GDI » Sun Jul 19, 2020 12:33 pm
Any clues?
B0GDI
Post by B0GDI » Tue Aug 11, 2020 9:39 am
Up
Bairs
Post by Bairs » Tue Aug 11, 2020 10:16 pm
Perhaps the problem is with the gateway itself in the subnet mask?
